How to treat magnolia teddy bear disease?
hamid16
 hi there,
 I bought a healthy teddy bear magnolia from Bunnings few months ago, I planted it in the ground in full sun position. Tree leaves turned brown and I can see dark spots on them. Can you please identify the problem? Many thanks
Re: How to treat magnolia teddy bear disease?
Hello @hamid16
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your magnolia teddy bear plant.
I suggest having a quick look at this discussion - How do I fix black/brown leaves of my magnolia plants? by @Pradeepk. It seems to me that your plant might be suffering from a fungal infection and a nutrient deficiency in the soil. But on closer inspection the other leaves don't have the tell-tale sign of black dots on all the leaves. The odds are that it is more likely a nutrient deficiency.
If that's the case, I recommend @Noelle's suggestion of using either Osmocote Rose, Gardenia & Azalea Controlled Release Fertiliser or Osmocote Plus Organics Rose, Gardenia & Azalea Plant Food & Soil Improver to provide those nutrients missing from your soil.
I also recommend checking your watering regimen, make sure that you are not over or underwatering the plant.
