Recently planted cucumber and chilli plants getting small holes and some leaves are turning yellow.
I didn't noticed any insects except black ants on garden bed timber.
Hello @sau1
Your cucumber and chili plants seem to be experiencing a combination of pest damage and possibly some nutrient-related stress. The small holes in the leaves could be caused by small chewing pests like caterpillars or beetles, even if they're not immediately visible. Black ants are often a sign of sap-sucking pests like aphids or scale, as ants are attracted to the honeydew these pests produce. The yellowing leaves could indicate a nutrient deficiency, overwatering, or stress due to the new planting.
To manage this, you could try using Yates Nature’s Way Vegie & Herb Spray, which is safe for edible plants and effective against common pests. If you suspect caterpillars, Yates Success Ultra is another great option. For the ants, sprinkle some Richgro Ant Killer granules around the base of the garden bed to reduce their activity.
Additionally, check your watering schedule—keep the soil moist but not waterlogged, especially for cucumbers, which are sensitive to overwatering. To address potential nutrient deficiencies, feed your plants with a balanced liquid fertilizer like Seasol PowerFeed or Yates Thrive Vegie & Herb Liquid Fertiliser. These will provide essential nutrients and promote healthy growth.
Keep monitoring your plants and inspect them closely, especially under the leaves, for any signs of pests. With consistent care, they should recover and thrive!
Hi @EricL , So I can use Yates Nature’s Way Vegie & Herb Spray for pests and liquid fertilizer like Seasol PowerFeed or Yates Thrive Vegie & Herb Liquid Fertiliser at same time?
For liquid fertilizer 'Scotts Osmocote Pour+Feed for Tomatoes & Herbs' and 'Seasol PowerFeed' or 'Yates Thrive Vegie & Herb Liquid Fertiliser' are same or there purpose are different?
Thanks!
Hello @sau1
I suggest spraying them separately so as to avoid negative effects. Give it at least a week before you add anything else to the plant. Read the spraying instructions at the back of the label to see how long you have to wait. In regards to the liquid fertilizer, their purpose is very similar, it's just a choice presented to you, to see which one you prefer.
