How to stop soil erosion through sleeper?
elizabethalex
This is the backyard of our newly built house. House sits on a mildly sloping land. Hence, builder did couple of sleepers. With last weeks rain there are holes in land as soil going thorough gaps in sleepers i guess. I am desperate for some solution for this before getting any worse.
Thank you
Most helpful
Re: How to stop soil erosion through sleeper?
Hi @elizabethalex,
I'd suggest digging out a trench behind the sleepers around 300mm deep and wide and attaching some GRUNT 1 x 10m Non Woven Geotextile Membrane Drain Mat Fabric to the back of the sleepers with Galvanised Staple Nails. The geotextile membrane should sit just above the soil line and be draped down into the trench. This will allow water to drain through while preventing the soil from eroding.
While your trench is dug, it would definitely be worth installing some subsoil drainage in the form of a french drain to divert any water to a suitable location or stormwater outlet.
Check out How to install garden drainage for some guidance on the materials and process required.
elizabethalex
How to connect french drain to storm water outlet?
thank you
Hi @elizabethalex,
As your stormwater outlet will be hooked into the council stormwater system, there are strict rules and regulations that need to be followed.
Unfortunately, connecting your french drain to a stormwater outlet will have to be done by a suitably licenced plumber to ensure these rules and regulations are followed.
