How to save dying Sliver Princess eucalyptus tree?
Dear Ms/Sir,
The Silver Princess (Eucalyptus Caesia) in my garden is mature and has always flowered normally including last year but this spring it has lost most of its leaves, many branches are dead and the bark is curling off the trunk. There is some spotting on the remaining leaves.
There has been no changes to its environmental conditions such as soil, watering etc.
Can you help me?
Thanks and kind regards,
Bluetongue
- Labels:
Gardening
Planting and Growing
Re: How to save dying Sliver Princess eucalyptus tree?
Hello @Bluetonge
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your silver princess eucalyptus tree.
It sounds like your Eucalyptus caesia (Silver Princess) is under some stress, which could be due to a few potential factors. The symptoms you're describing—leaf loss, dead branches, curling bark, and spotting on remaining leaves—may indicate a fungal disease or root rot. Although Eucalyptus caesia is typically resilient, it is somewhat vulnerable to pathogens like Phytophthora root rot, which can cause dieback and similar issues. Even though you haven’t changed the watering or soil conditions, fungal diseases can still take hold, especially after unusually wet periods or if soil drainage isn’t optimal.
Environmental factors may also be playing a role. Mature Eucalyptus trees can sometimes react to delayed stress from extreme temperatures, such as a cold snap or sudden heatwave, even if these happened a season or two ago. This delayed response can appear in the form of leaf drop and bark curling. Additionally, pests or diseases may be involved in the spotting on the leaves, as Eucalyptus can sometimes suffer from pests like psyllids or eucalyptus beetles, or from fungal leaf spots caused by pathogens like Pseudocercospora or Alternaria.
To address these issues, consider pruning any dead branches to encourage healthier growth and prevent the spread of disease. A fungicide treatment specific to eucalyptus or trees, in general, could help if fungal disease is indeed the cause. It may also be worth carefully examining part of the root system to check for any signs of rot, such as soft, discolored, or foul-smelling roots. If you suspect root issues, improving soil drainage could help reduce further damage.
However, looking at the trees current condition, I'm not sure if it can still recover. I also suggest engaging the services of an arborist to give you a more in-depth diagnosis.
Let me call on our experienced members @Noelle and @mich1972 for their recommendations.
Hi @Bluetonge
An arborist's opinion on the viability of your tree would be well worth the cost but, to me, unfortunately its appearance looks terminal.
Hi Eric and thank you for your prompt response.
This is what my arborist says " It doesn’t look good for the Silver Princess Eucalyptus caesia. This species is very prone to fungal disease. The species originates from Western Australia which is much drier and has less moisture levels compared with southeastern Australia. As a result the species can more easily succumb to fungal infection and eventual defoliation. The tree may reshoot and put on new growth with the warmer weather. You could try using fungicide but this requires spray equipment and I’m not sure on the success of this etc.
My initial advice would be to:
- Make sure the tree is not over watered and if possible improve drainage (if this is an issue).
- Remove infected leaves.
- Monitor tree for new growth over the next month.”
So it appears you too Eric know what you are talking about. Thank you for your sound advice.
I will make an assessment as described above and in your email to me and proceed from there.
Thank you Eric and the Bunnings Workshop team.
Kind regards,
Bluetongue
Thank you Noelle.
I will try and save the Silver Princess and will keep you and the Bunnings Workshop Community in the loop.
Thank you and kind regards,
Bluetonge
Subject | Author | Posted | |
November 2023 | |||
December | |||
April | |||
July 2021 | |||
October 2023 |
