How to lift turf and level lawn?
dannymel
I would like to lift up lawn for my garden. because slowly loosing soil and moved to another land.
Please advise how to lift up the lawn around 15-20cm. I need to make a flat with path way.
Re: lifting turf / levelling lawn
Hi @dannymel,
Could you please provide our helpful members with a little more information about where this pathway will be running and if that will be part of the levelled area? That way, they'd be better informed and able to offer useful advice.
Lifting all the grass over the depression would be a fairly large job. Manually it involves using a spade to cut incisions in lines along the grass and then coming back and cutting underneath the grass to remove its roots along with some soil. You must cut underneath it deep enough to preserve the roots without severing them all off. This would be approximately a 50mm depth of soil. It will be hard going. You might like to read through this discussion: Have you used a turf cutter for turf removal?
Once the turf is removed, you can fill the height with underlay soil or, for the best value, order a bulk delivery of landscape lawn mix. You'll then be able to re-lay your lawn. Ensure the lawn is kept in a cool location and slightly damp by misting it with water until it can be transplanted.
