Hello
i I want to hand over a U shaped pipe to exposed aggregate person so that he can put it underside before laying the concrete.
i want to use this pipe in future to run a water line across
can any one suggest what size pipe and what fittings and how to make it so that Concreter has no issues laying it before concreting
Hi @Salam123,
Thank you for your question.
Similar to your question about installing an electrical conduit, this is something you will need a plumber to assist with to ensure it is installed to the relevant standards.
If you don't have a plumber you have used before, you can find someone local to you using a service such as HiPages or True Local.
