adria_wang
How to fix my lawn?
Hi everyone,I’m a total beginner when it comes to lawn care, and I could really use some guidance. My backyard is looking a bit rough, and I honestly don’t know where to start. I’m not sure what type of grass I have, how often I should water, or even what tools I need to take care of it properly.Right now, the lawn looks patchy in some areas and overgrown in others. I’ve seen terms like “aerating” and “overseeding,” but I’m not sure if that’s what I need. I also don’t know the right way to mow or if I’m over- or under-watering.If anyone has advice, tips, or even links to beginner-friendly resources, I’d be so grateful. What are the basics I should know? How can I figure out what’s going wrong and fix it?Thanks in advance for any help—I’m excited to learn and get my lawn looking better!
Re: How to fix my lawn?
Welcome to the Bunnings Workshop community @adria_wang. It's sensational to have you join us, and many thanks for your question about lawn care.
It looks like your lawn is suffering from a few common issues, but don’t worry—there are ways to bring it back to life.
I recommend starting by aerating the entire lawn, especially the compacted areas where the grass has died back. Aerating will loosen the soil, allowing air, water, and nutrients to reach the roots. After aerating, apply a moss killer like Manutec Moss Killer & Lawn Food to eliminate the moss and provide your lawn with a much-needed nutrient boost. Once that's done, topdress the entire lawn with about 10-15mm of topsoil, being careful not to completely cover the grass blades, as you still want some green to show through. Finally, you can overseed the lawn with new grass seed to fill in the bare patches.
As for the basics of lawn care, generally, most lawns need to be watered deeply and less frequently, at least twice a week or more during dry periods. Mowing should be done regularly, but avoid cutting the grass too short, as this can weaken it. Aim to cut no more than one-third of the grass blade's height at a time. Keep an eye on your lawn to see how it's responding and make adjustments as needed. Currently, your lawn is cut very short, and you can afford to let it grow out some more, which will help it fill better.
Here's a helpful guide: A seasonal guide to lawn care.
