How to fix leak in retractable hose reel?
Arko1923
Re: how to fix leak
Hello @Arko1923
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your garden hose reel.
One of the first things I would investigate is if your garden hose reel is still under warranty. If it is, I suggest tracking down the purchase date on your bank statement, but if you used cash perhaps you can track down your docket. You can then bring the faulty hose reel to the store and apply for a warranty.
However, if neither of those options are open to you, I can only suggest pulling the reel to its maximum length and investigate if the hose itself has sprung a leak. The hose itself can be patched up, but please do not open the hose reel housing as there is a high-tension spring located inside and is not meant to be tampered with as it could cause severe injury.
Re: how to fix leak
Hi Eric. We have this retractable hose and the actual hose has a split. Do you recommend anything to fix the split in the hose? Thank you!
Re: how to fix leak
Welcome to the Bunnings Workshop community @elanahealy. It's wonderful to have you join us, and many thanks for your question about repairing a hose.
Silicone tape could potentially be used for a somewhat temporary repair.
As mentioned by @EricL, Nylex retractable reels have a three-year warranty, and if you are still covered, it would be best to exchange the unit. Alternatively, as per your user manual, in the event of the hose failing, Nylex advises that you contact them on Ph: 1800 335 019 for further instructions.
Re: how to fix leak
Great thank you for that! 👍
