How to fix Ryobi mower not working?
Therese2
do you offer servicing? My ryobi mower is not working as it should. Mainly the clippings are not going into the catcher and therefore clogging the blade and shutting down the motor. It’s still under warranty but I think it might need a blade sharpen or something 🤷‍♀️ please help
Re: How to fix Ryobi mower not working?
Hello @Therese2
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Ryobi lawn mower.
Depending on your lawn mower model and the number of hours you've been using it, it's possible that the lawn mower blade has worn out and needs to be replaced. If you still have your owner's manual, you'll see exactly how many hours the blade is rated for and a recommendation on when it should be replaced. Your owner's manual will also show you the blade number that's compatible with your mower.
However, if after replacing the mower blade and it still does not throw the clippings into the catcher, further investigation may be needed.
