How to fill and level an uneven backyard?
simont
Hi, I just got keys to my place, and I need to perform some basic landscape at the backyard.
Currently, the backyard is uneven, and its level is much lower than the finished floor level. I am thinking of filling and leveling up the backyard and have it all covered with lawn with a garden bed running along the boundary/fence.
Seeking some advice on the following:
1) What's the best material to fill up? I was thinking just the usual topsoil will suffice?
2) Are there any other works/tasks I need to perform, or just simply fill it with topsoil to the required level will do?
3) Size is approximately 3.5m (width) x 6.5m (length) x 0.35m (height), equating to 8 cubic meter. Do I need to factor in any compression factor to estimate the amount of soil required?
4) With the black plastic liner (the liners that are part of the concrete slab), can I put soil above it, or do they have to be 'lifted up' and 'tucked' next to the slab?
5) Around the sewer riser, there is a deep depression, presumably left by the builders when connecting to the sewer line. Any different requirement to filling it up around the riser, or topsoil will do?
Photos attached.
Plastic LinerPlastic LinerPlastic LinerPlastic LinerBackyardBackyardSewer RiserSewer Riser
Thanks in advance!
Re: Backyard - Filling / Levelling
Hello @simont
Thank you for sharing your question about filling and levelling your backyard for new turf.
Before you cover the area with topsoil, I suggest having a quick look at these discussions - How to remove existing lawn and lay new turf? by @ArunM and How to prepare land for re-turfing? by @VijayWani. It's important that your existing soil be prepared to receive the new quality topsoil so that you'll get good drainage. Removing all the solid objects such as rocks and boulders will definitely help getting the soil level.
I propose thinking about adding perhaps an extra 1 cubic meter for soil settling. Once the soil is in place, I recommend using a lawn roller to level the surface and remove any air pockets that might have been trapped underneath. In regards to the plastic, make sure to fold them away and push it underneath the slab. As to the deep depression near the sewer line, I suspect that this has occurred due to poor maintenance. Once the area is level and filled with topsoil it should now drain properly.
Here is a handy step-by-step guide: How To Lay Turf.
