How much potting mix needed to fill a raised garden bed?
zoe63
Hello
Can you please advise how many bags of potting mix you need to fill the following -
Fountain Products 610 x 510 x 240mm Charcoal Raised Garden Bed with Wheels - I/N: 0117520
Thank you in advance.
Kind regards
Zoe Hoopert
smokey1507
Re: How much potting mix needed to fill.... see below
Here's the equation to work out cubic metres required to fill this and any other similar product w×d×h in metres. w= width, d=depth and h= height. So 0.61×0.51×0.24= 0.074664 or...0.07 cubic metres. Bags of potting mix comes in 25kg bags. 25 litres of potting mix converts to .025 cubic metres. 3 bags of 25 litre potting mix should do the trick. Here's a list of options https://www.bunnings.com.au/search/products?page=1&q=25+litres+Potting+mix&sort=BoostOrder
Re: How much potting mix needed to fill a raised garden bed?
Welcome to the Bunnings Workshop community @zoe63. We're pleased to have you join us.
You might like to check out the step-by-step guide How to fill a raised garden bed by experienced contributor @Noelle. In step 4, Noelle explains how to determine the number of bags of potting mix needed by calculating the volume required. For example, a bed measuring 1.5m wide x 2m long x 0.3m depth of potting mix will need 0.9 cubic metres, which is 900 litres (1000 litres is 1 cubic metre).
We also have a collection of Best Advice from our members on this same topic here - How do you fill a raised garden bed?
We look forward to reading more about your projects and plans for around the house and garden.
Hi @zoe63
It's great that you've received excellent advice from our members. Just remember to keep in mind to choose the right soil for the plant you are planning on putting in.
