Materials
Tools
Drop Saw (can use hand saw)
Cordless Drill
Orbital Sander
Hole Saw Drill Bit - I used this set (https://www.bunnings.com.au/craftright-16-piece-holesaw-set_p6372275)
Steps
123456
Step 1
1/6
Firstly I used a drop saw (you could use a hand saw) to cut the 1.8m Pine into two lengths of 70cm. You could customise this length to suit the amount of pots you wish to use.
Next Step
Step 2
2/6
Next I measured and marked out the centre of each pot position. I thenused the hole saw attachment to drill the holes for the pots to sit in. Make sure you choose the right size hole saw depending on the size of your terracotta pots!
Marking out the centre of potsMarking out the centre of pots
Previous StepNext Step
Step 3
3/6
Next I drilled a 6mm hole in each corner (where the rope will go through) before using the orbital sander to give it all a quick sand.
 Drill holes in every cornerDrill holes in every corner
Step 4
4/6
After sanding it back I sprayed each piece of timber with the Cabbots Clear Satin Exterior Spray. This process was so quick and easy to do with the spray can and meant there was no paintbrushes to clean up!
Step 5
5/6
Once it was dry it was time to assemble. I threaded the rope through the holes (see image below) and with the help of someone to hold the top tier in place, I used the wire rope grips to secure the top tier in place.
Image to show how the rope is threadedImage to show how the rope is threaded
Step 6
6/6
Once it was all assembled, I hung it on our front porch and then spent a bit of time adjusting the rope to make sure each tier was level. Then it was time to plant the herbs and watch them grow!
Previous Step
Re: Hanging herb garden
Fantastic project @sammilne. I love the simplicity of the design matched with the terracotta pots. Great aesthetics overall.
Well done, and many thanks for sharing.
robchin
Becoming a Leader
Loving this @sammilne
Wonder if I can find a spot for one 😁
Benskimo
Making a Splash
Really neat job @sammilne , well done, and I agree with @MitchellMc - such a nice aesthetic. Can I ask: how did you secure it to the ceiling/beams of wherever it's hanging...?
mich1972
@sammilne Simple is best !! I love it, enjoy your Herbs 🌿 😀
