Steps
Step 1
1/1Fed the Round Rings onto the Panel Fix Clips.
Removed the nuts on the bolts that support the fence to the posts and attached the Jacks Mesh Panel Fix Clips at either end then secured the nuts back on to the bolts. Fed the Wire Rope Thimble through the ring at one end.
Hooked the Turnbuckle through the ring at the other end and connected a rope thimble to the turnbuckle.
Attached Mesh Panel Clips to the middle Posts as added support for the wire.
Fed the wire rope through the clips and around both thimbles.
Secured both ends with Wire Rope Grips using an adjustable wrench to tighten with a small amount of slack in the Wire Rope.
Secured the surplus Wire Rope with Zip Ties along itself to make it neat and tidy.
Rotate the Turnbuckle to tighten the slack.
All that is left is to train the Vine along the wire, gently tighten the turnbuckle if the vine weight causes wire to drop and prune as necessary then just wait a few seasons for the grapes to grow.
I painted the fence first using Walpamur Charcoal Fence Paint as I find the green vine leaves or any green leaved plant really pop in front of the Charcoal coloured fence. Also in Winter the Grape Vine loses its leaves and the painted fence looks nicer than boring aged hardwood palings.
Re: Grape vine supported between fence posts
Looks great @Bankzee, well done.
I'm sure this project will be popular with other Bunnings Workshop community members as fence screening solutions are always in demand.
Thanks for sharing.
Good Afternoon @Bankzee
Nice way to use some not used so much space! I did have two grape vines ... did is the word They died as I forgot to water them (they were in pots)
I was going to go to the expense of posts and mesh but like the way you have done it.
Will keep that in mind for my next "try"
How fast do the vines grow in general? Its something I have always wondered about?
Hi Dave,
Thanks for the compliment. The grape vine seen in the picture is 2 years old but I have noticed that since I have started training it along the horizontal wires it has started to speed up its growth, not sure whether this is caused by the horizontal support or the abundance of rain and sun we have had recently. The fence is on my western boundary so the vine faces east so gets in excess of 6 hours of sunlight. Grape vines do need a bit of water and their root system needs some space to spread out so Pots are not ideal unless you intend to keep the water up to it and give it a regular haircut.
The photo I have attached below is an ornamental grape vine and trellis project I did on the western facing brick wall of my house. I designed it as a solution to keep the sun off the brick which has reduced the heat inside the house tremendously. The bricks are no longer a heat sink and most importantly when I need the heat in winter, the vine loses its leaves so a win on both counts, not to mention how good it looks. This vine is 4 years old and grows at a very rapid rate, it provided shade over the whole wall in 2 years. It is so rapid that the vine grows about a foot a day in ideal conditions. This is a single plant that is planted beneath the window on the left. I now find myself training it to the front of the house and will continue to do so as long as it keeps wanting to grow.
I can do this as a Workshop Project post if there is interest.
Ornamental Grape shading the West Wall
Now that is a brilliant idea with keeping the heat off the bricks! I have deciduious trees in my front yard, liquid ambers (I top to keep them in line), crepe myrtles and a fig tree. In summer the yard is shaded by all the green foilage and in winter "boom" they all drop their leaves
Dave,I was quite chuffed with the Ornamental Grape and Trellis, it was so simple once I got past the fear of drilling into my house bricks. The brick temp has reduced by about 10 degrees in Summer which makes such a difference to the internal temp on that side of the house late in a summer evening.
The liquid ambers must put on such a show in Autumn for you, I thought about such trees in my front yard however as it is rather small and sitting higher than road level with an old sandstone retaining wall I decided to avoid any medium to large trees whose root system may not appreciate the work and cost involved in replacing said retaining wall.
As for the fig, I have one of those just up from the Grape that the original post showed. What I did with it was get the two main branches, each measuring about 2 metres, and trained them to grow along the base of the fence to the left and right of the centre trunk. This now ensures a wider coverage of the fig tree and instead of a single tall Fig, I have all these vertical branches coming up from the two laterals which increases fruiting area and also provides a nice green foreground in front of the paling fence. As seen in the below pic.
But despite all this, I would give them all up for a beautiful Liquid Amber and Crepe Myrtle in my front yard.
Have added a photo below that shows another benefit of the Ornamental Grape, it frames my dining window when looking out into the backyard. Such a treat especially when the small birds hop through the vine looking for caterpillars.
Dining Window Framed
Banksy
Hi @Bankzee I am very interested in this project as having a north facing wall that gets extremely hot in summer. Have been looking for solutions and came across Ornamental grape vine as an option. Would you be able to let me know how to train it horizontally on a brick wall, please? E.g. how often or how far to attach a horizontal wire from another to have the wall completely covered. How many plants to use and where is the best place to locate them, middle? on the sides? It looks fantastic in this photo.I love the ground too! Thank you
Hi @marcequin . the ornamental grape vine over my west facing brick wall works so well. As it is the colder months here in Canberra, the leaves have changed colour and almost finished falling off the vine, leaving the brick exposed to catch the winter sun. The resulting leaf litter on the ground makes a great mulch for the garden.
For the wall installation I drilled 7mm holes in the brick using a masonry drill bit. Inside this i placed 7x35 Ramset wall plugs. I then screwed Mesh Accessory Panel clips into the wall plugs and placed panels of Jacks Grip and Grow along the brick wall. This pic shows a close up of the panel clip holding the trellis. I used 6 of these clips per trellis but this is likely more than necessary.
How to train it horizontally - The vine on the wall did its own thing, I just helped guide it in the direction it wanted to go. But you can guide the vine any where you want along the trellis
How many plants to use - The following pics are one plant show before and after with another pic showing how it looks in winter.
It is planted beneath the window on the left. I am now guiding it around to the front of the house as I like the look.
I am more than happy to answer any questions you may have. One thing I will say is you will need to trim it from the gutters during the growing season so it doesn't fill them up. As you can see in the above pic, I keep it away from the roof.
kind regards,
Bankzee.
Welcome to the Bunnings Workshop community @marcequin. It's great to hear about your project. I trust that @Bankzee's reply has answered your questions.
Please keep us updated, and feel free to start a discussion if you need further assistance. We'll be keen to see your results.
This is great @Bankzee. Thank you so much. I just came back from Canberra and loved the weather and autum look. My project is in WA on a solid north facing brick wall which gets really hot during summer. I might try this to decrease the temperature. Have a great weekend ☺️
Subject | Author | Posted | |
March 2024 | |||
July 2021 | |||
March 2024 | |||
April 2024 | |||
October |
