Hi. I have just bought an Ozito 12v cordless drill. Could I use the battery from that in an Ozito 18v Circular saw or other Ozito power tool.
Hi @JGB,
Thank you for your question and welcome to the Bunnings Workshop community, it is fantastic to have you join us.
I apologise, but it appears that a regular charger has been placed in a box where a fast charger was supposed to be. You can see in the top right-hand corner one says 18v Li-ion and the other says 18v Fast Charger.
Sometimes "opportunistic" people will put lower quality products in the packaging of higher quality products that look similar to them. For this reason, it is often wise to double-check the product before leaving the store.
I'd suggest returning the product to your store of purchase with your receipt, explaining the issue to the helpful team members in the Tool Shop and exchanging it for the correct one.
I'm sure there won't be any issues, but I am happy to assist further if required.
Hey, I have a question. I have the ozito blower then I bought an Ozito blade trimmer (whippersnipper). Both haave compatible batteries. But when I bought an Ozito drill and a hammer drill the batteries are not compatible with the blower. Are there any adapter? Thanks
Hello @hacruz
If the Ozito drill/Hammer drill you purchased has the Ozito PXC logo on it, then it should be compatible. But if not, then the PXC battery system will not work for your drill. I'm sorry, but there are no adapters available to switch from one system to another. If you still have the packaging and docket for the drill, I propose thinking about returning the drill and exchanging it for a compatible set.
