How to sharpen Ozito cylinder and rotary mower blade?
softkun123
Hi there
I have Ozito 18v Cydlinder lawn mower and Ozito 36v 370mm lawn mower.
How do i sharpen Ozito cylinder and rotary mower blades?
Regards
KK
Re: How to aharpen Ozito cylinder and rotary mower blade?
Hi @softkun123,
For the Ozito PXC 18V 380mm Cordless Cylinder Lawn Mower, you'll find care and maintenance advice in the user manual. It's important to identify if it's the blades that need sharpening or if the cutting bar just needs adjusting. If the cutting bar is adjusted correctly, the blades should self-sharpen. I'll include the section below. Remember to use extreme caution around the blades and keep your hands away from them, have the battery removed from the tool and be wearing cut resistant gloves.
For the powered lawn mower, you might find it more convenient to replace they blade periodically rather than try to sharp it. If you can show us a close up image of the cutting blade then we can advise on whether it could be sharpened or needs to be replaced.
