How to select safe abrasive cutting discs?
Anyone ever done this?
I'm tone deaf - this is from a 9" grinder/cutter manual from 1999.
I can't imagine Bunnings staff approving of me tapping their discs with a wooden mallet.
Thing of the past with better manufacturing standards?
Cheers.
Re: How to select safe abrasive cutting discs?
There is no need to tap the discs constructed with current technology @Noyade.
Here's a helpful pre-use checklist from SafeWork SA.
Before using an angle grinder, ensure that:
- the guard and handles are secure
- there are no defects or damage to the disc (a disc which has been dropped may have developed cracks and should not be used)
- the correct flange and locking nut is in place for the type of disc being used (otherwise the disc can shatter at high speed)
- the tightening tool supplied by the grinder manufacturer is used to tighten the disc as other methods can damage the disc and grinder
- the correct disc diameter and central disc hole size for the spindle is used
- the correct type of disc is used for example grinding discs for grinding and cutting discs for cutting
- the correct type of disc is used for the material being cut or ground.
Thanks.
The background is the blade style below. 'Discovered' them recently - 230mm diameter with a 35mm arbor.
I'm thinking 40 years old?
They do not 'ring' - 😁
Cheers.
That watermark alone would be a reason to dispose of them, @Noyade. They are much too old for my liking; I'd get rid of them to ensure you don't mistake them for new blades.
Subject | Author | Posted | |
April 2023 | |||
January | |||
January | |||
October 2021 | |||
January 2023 |
