Hi all, this is my first post.
The ceiling boards of my garage have started to fall down. They were originally nailed to wood beams above but the nail holes have worn through over time.
What would be the most effective way to re-attach them?
I thought I could use a screw driver and screws straight through the board into the wood, but I wasn't able to get it to pierce the board above my head.
Would a staple gun work? I don't have any experience but I think the staple may not bind to the wood effectively?
The garage was built in the early 1980s.
Hello @hammer_user13,
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing your question about your garage ceiling panels.
Before you make any more attempts to secure your ceiling panels, I suggest having it tested for asbestos. Houses from the late 70s to the early 80s were constructed with materials containing asbestos. Your ceiling panels might have asbestos in them.
Generally, I recommend using plasterboard screws when attaching ceiling panels to timber framing. But before you make any attempt to repair it, please have it tested. Once you are sure that it is not asbestos you can then proceed with the repairs.
