How to install Polycarbonate sheet?
Latzi
Hello there,
I need to install flat polycarbonate twinwall panel 3x1m. as sheed but don't have access from the top to drive scrrews to the battens. Is there any way to secure sheet from the bottom any special screws?
Thank you,
Latzi.
Re: Polycarbonate sheet installation
Hi @Latzi,
Unfortunately, there is no way to screw panels onto a roof from the underside. This is because the screws used for this kind of installation, like these Suntuf Clearfix Roofing Screws, have a rubber washer that compresses against the top of the sheet to create a waterproof seal.
Is there just a frame currently? Or is there already sheet material on the shed?
If there is just a frame, you can often work from a ladder placed on the inside of the shed and work across to the last panel which can be screwed off by placing your ladder close on the outside of the side of the shed.
If there is already roofing material in place, you may need to remove some panels and follow the above process to reinstate them.
Alternatively, contacting a handyman to assist might be a good option.
Latzi
Thank you Jackob,
There is no framing yet. I have to build one. But yes looks like I will have to install 3x 1m. panels and join them. I was trying to avoid joins but its not possible.  Thank you for advise.
Latzi
