Does Bunnings cut wood to size?
Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include Melamine and Plywood.
What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
Noyade
Re: docking and ripping melamine 16mm board
Just a dumb question @MitchellMc
If the customer is unhappy with the quality of the cut, does the 'saw/man/woman' cut more sheets until satisfaction is achieved - or by this stage does the store manager step in as arbitrator?
Hi @Noyade,
The service is provided to assist customers to transport the goods home easily and not a precision-cutting service. While the quality of the cuts is almost solely determined by the machine, feel free to speak to the in-store team if you ever need further assistance.
Noyade
All good.
I was witness to an argument late last year in store at the sawing area.
I shuffled on.
But I was wondering how it was resolved.
Cheers.
jbsykes
I need a small amount of 150 x 50 H3. Can you cut it to size for me?
Same as  title
Re: I need a small amount of 150 x 50 H3. Can you cut it to size for me?
Hi @jbsykes,
Our full-size warehouses have cut shops that can cut timber to the nearest 100mm of length for transport. However, you will have to purchase the full length of timber.
leoncho
Do bunnings cut a curve shape
Hi
I would like to build a custom corner table unit between my ikea drawers
Should i use ply, mdf, melamine or timber
and also do bunnings cut the curve corner
Re: Do bunnings cut a curve shape
Welcome to the Bunnings Workshop community @leoncho. It's wonderful to have you join us, and many thanks for your question about cutting curved shapes.
Unfortunately our saws can only make straight cuts and for your curve you'd need to do that at home with a jigsaw.
You could use plywood, though you would need to finish the cut edge with a moulding to make it look neat. MDF isn't typically used as a finished desk surface, but does look quite nice sealed with a polyurethane coating. Melamine is an option, but you'll need to add laminate edging to cover the exposed particle board core where you've cut.
The other option would be to use one of our timber panels. 980mm is quite wide, and typically 900mm like the Specrite 2400 x 900 x 33mm Timber Multi-Use Pine Panel is the largest size.
PhilGeo
Which Stores
Does Bunnings Collingwood or Burwood Road Hawthorn offer a timber cutting service?  Just two small pieces
Re: Which Stores
Welcome to the Bunnings Workshop community @PhilGeo. It's sensational to have you join us, and many thanks for your question about our timber-cutting service.
I apologise, but Bunnings Collingwood and Hawthorn do not have a cutting service. The nearest store to that area with a cutting service would be Bunnings Preston.
This service is available to select timber products purchased in-store.
faro82
MDF CUT
I was at Bunnings to buy some MDF panels, and they told me they can only cut timber or plywood, but not MDF. Is that true?
