We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
I just order 5 panel from Bunnings, unfortunately they don't cut the panel for me. I can cut at home but it is quite big for my van.
That's certainly a tight fit @Fatsquare. Well done!
Please keep us updated on your project and reach out if you need assistance.
I have just been refused this service at Bunnings Malaga WA, I was told by a team member, then store manager, they will cut timber to fit it in a vehicle but not to size for a project. What use is this? Not happy😡
Hello @highpsi
Welcome to the Bunnings workshop community. It's wonderful to have you join us.
I'm sorry to hear that you could not get your timber cut. The reason for this is that the panel saw at the store is not made for precision cutting.
I suggest having the panels cut close to the size that you need. You can then do your precision cuts at home. For example, if you need a panel that is 500mm add an extra 50mm to either side so that even if the cut is uneven, you have a buffer that allows you to cut it to the size that you need.
Can you please tell us the sizes you need the panels to be cut at? The added information might help us with a way to cut the panel.
If you still need assistance at the Malaga store, please let me know I'll be more than happy to give them a call.
I was purchasing a sheet of 3mm mdf and wanted it cut ( total 4 times) to give me 2 pieces (plus waste)
required sizes
725x585
735x535
the whole reason I want it cut, is I don’t have a shad/workshop and limited tools, I’m also disabled (post stroke) and cutting a straight line that long with hand tools is not going to happen
Hello @highpsi
Allow me to make contact with you through PM so that I can provide you with further assistance.
Thanks. Done. Change the dark blue color carpet to Qs laminated floor, have repaint all windows and door trim. And install the vj panels finally.
I found the panel is really hard to connect the joint tightly. You have to push hard by using hammer and blocks to give the panel a push. And because it is MDF panel so if you push hard , it may do some damage to the panel edge. And especially the corner panel, there is no way and no room to push.. so I have to leave some minor gap(1-2mm) between each panels, and fill with no gap filler before painting.
Anyways, the finished is lovely.
And thanks for all helpful info from Bunnings workshop.
It's great to see a successful project @Fatsquare. Your room looks amazing, and many thanks for sharing the results with us.
Well done.
Great work @Fatsquare.
You might like to hit the Share a project button and share your handiwork in a dedicated post so it gets the attention it deserves. I'm sure our members would love to hear more and be inspired by what you have done.
Congrats.
Long time lurker, first time poster here.
I have some projects in mind that will involve some large panels (2400x1200) that I will be purchasing from Bunnings Kingston (TAS). I have a cut list, but my experience with other lumber yards is that the cuts requested can be off by quite a bit.
Like many DIYers, I do not possess the means to transport a large panel so my options are limited to delivery, trailer hire, in-store cutting services, or being that guy in the carpark with a portable circular saw to get it in the car.
So the question is how accurate is panel cutting? Will I need to add a substantial tolerance to my measurements, or is blade thickness sufficient? I just need the pieces small enough to get in a station wagon where I can get them home to the table saw for final sizing. The other consideration is the straightness of the factory edge...
If anyone has any experience or advice to share it would be greatly appreciated.
