I am planning to build a mountable bathroom cabinet (see attached) from https://www.bunnings.com.au/2440-x-1220-x-16mm-white-pvc-foam-board_p0495500
I want it matt.
What would you recommend to use as a base and a paint?
Thank you!
Hello @ivk
Welcome to the Bunnings Workshop community. it's sensational to have you join us, and thanks for sharing your question about painting PVC panels.
I suspect that an aqua enamel paint will work on its surface, but please allow me to double check with our supplier if any particular primer is required before painting it. As soon as we have more information, we'll get back to you.
Thank you for your patience.
Hi @ivk,
It would be best to give the surface a quick scuff with some 240-grit sandpaper to abrade and key it. You then need to use a specialised primer such as Dulux 1L PRECISION White Maximum Strength Adhesion Primer, which is suitable for PVC. Once the primer is dry, you can apply your topcoat paint. As @EricL mentioned, Dulux Aquanamel would be a suitable paint to use as the topcoat.
Thanks a lot!
If I also may ask you what will be the suggested way to cut https://www.bunnings.com.au/2440-x-1220-x-16mm-white-pvc-foam-board_p0495500
Can I use a circular saw with some tracking attached like Accu-Cut or do I need a plunge/track saw? Hight tooth blade? Specific speed?
Hello @ivk
Yes, you can use a circular saw or even a track saw to cut the PVC panel. A high tooth blade would be much better of course as you'll get a better cut. The standard speed of your circular saw should suffice. Just keep in mind that both sides must be clamped and supported at the bottom while it is being cut.
