I have all of a sudden got an issue where the water going to my washing machine through the cold is having almost no water coming through. It doesnt seem as though any other tap is having a problem. I have taken the hose off and the water pressure is still very low coming from this tap. Any suggestions on how to correct this or do you think I will need a plumber?
Hi @renegade2k,
Thank you for your question about low water pressure in your laundry.
I'd suggest you inspect the tap, aerator, and any filters for blockages, and clean them thoroughly to remove any sediment or debris that may be affecting water pressure.
If this does not fix the issue, the tap may be air-locked. Airlocks occur when air becomes trapped in the pipes, creating a blockage that restricts water flow.
Turn on all taps in the house, starting with the lowest tap and ending with the highest. Leave them open for several minutes to help push the trapped air out of the system.
Allow me to tag some of our helpful members to see if they have any ideas that might help, @Dave-1, @Nailbag, @Noyade.
Unfortunately, if these troubleshooting ideas do not prove useful, it is likely you'll need to contact a plumber for assistance.
