Laundry renovation using Kaboodle cabinets
Sara_T
Our laundry was stripped back to bare by our insurers workmen right before cyclone Jasper. The trades focused on those who needed it the most-leaving us to redo our laundry ourselves.
A Bunnings kitchen consult, modern tile and Porters paint brought our dream to life!
it was a little hard to photograph because it’s such a narrow room. Last photo is before.
Now on to the kitchen!!!
Materials
Benchtops BENCHTOP CTM KABOODLE++600MM 38MM BAMBUCHA C-52877 90927 3 $624.12
Cabinetry
2X35L LAUNDRY HAMPER KABOODLE++SUIT 450MM BASE CAB W-
50538 137874 1 $281.00
BASE CABINET KABOODLE++450MM W-51604 2662608 1 $135.45
BASE CABINET KABOODLE++600MM W-51605 2662611 2 $280.00
BASE END PANEL KABOODLE++MOLV D-69161 77175 5 $1224.70
CABINET DOOR KABOODLE++300MM MOLV MOD D-69135 77099 14 $1555.82
CABINET DOOR KABOODLE++450MM MOLV MOD D-69137 77105 1 $141.75
DOOR BUFFERS KABOODLE++75PK FOAM W-50302 2662000 1 $9.80
DOOR HINGE HETTICH KABOODLE++SOFT CLOSE 1PK W-50375 2666429 15 $454.50
KICKBOARD KABOODLE++2400MM MOLV D-69174 77211 1 $141.75
OPEN SLIM SHELF CTM KABOODLE++600-699MM SLIM MOLV D-
77696 384206 5 $1734.45
STICK ON SCREW CAPS KABOODLE++100PK PLASTIC W-50300 2661998 1 $5.80
WALL CABINET KABOODLE++600MM W-51624
Porters paint Aniseed and Rubble
blue painters tape
Laser level
Strip lighting
black silicone
from elsewhere:
shelf hanging kit. It would be great if Bunnings stocked one!
Tools
Steps
Step 1
Build all the cabinetry and spend a fair bit of time adjusting them and attaching them to the wall. Attach baseboard.
affix doors to upper cabinets and spend a whole lot of time learning how to adjust them because you’ve never done that before.
install bench top.
(plumber put in sink and tiler did tiling).
Edge the tiles/baseboard with black silicone.
Pop on bottom cabinetry doors and install shelves.
paint 2/3rds of the room (including the roof rubble). Use the laser level to help you tape up the 1/3 of the laundry and paint it in aniseed.
fill to the brim with craft gear now you have heaps of storage.
I can’t work out how to edit materials. We didn’t end up using the open slim shelf and painted the area instead to give the effect we were after.
Re: Laundry- Achievement unlocked!
Nice work @Sara_T!
You've done a brilliant job with your laundry.
It's a stark contrast to the white walls, but I love the choice of colours. Those Porter's Paints look great, and they match your Lugna built-in hallway storage project so well.
Thank you for sharing your wonderful laundry project.
