Hey all
We got a new Bosch washing machine and a tumble dryer
You can connect a drain hose to the dryer so you dont have to empty the condensation collector every few dry cycles
But we only got one spigot for the washer
I was thinking if its possible to get a Y adapater and connect both the washer and the dry drain hose to that. Then connect the Y adapter to the spigot?
The dryer drain hose seems like a smaller one vs the regular size washing machine one
see the photos of the drain hoses
It could be possible to utilise that hose @PatDIY_Dad. However, you'd probably need to cut one of the ends off the Bosch hose and push it onto the back of the machine. Then, you'd need to push this hose end over that and use the clamp. I'm not a great fan of you cutting up the Bosch hose to achieve that, as there's a possibility it could still leak. At this point, I think it'd be best to try to cobble together a connection for the trap with the products I've mentioned above. As I don't have one of those Bosch hoses to verify the fittings on, I've selected what I think would work, but you'll need to double-check.
Yeh I realized it would be too long
I just got all those bits and trying to put them together
The Bosch hose is basically the same size as the smaller end of the adapter
Did you mean to fit the hose over the adapter? Will be very hard to fit it on
Hi @PatDIY_Dad
Any chance that you can stretch the Bosch hose in hot water? Is the Bosch tip hard or soft? If it's hard, perhaps you can run a 13mm clear hose between the reducer and the hose. The only other option is to reduce it even further with a Holman 13mm Barbed Poly Joiner, this goes from 13mm down to 10mm. You'll need to get some 13mm clear hose and three more clamps to secure the reducer.
