My hand-held shower pipe is leaking so I believe it needs replacing. Is it as simple as buying one of the same size or do I need to apply any paste/tape to the screw when i fix the new one to make sure it seals properly. I've included a photo of what I am referring to
Hi @yohfdo,
Where is the pipe leaking from? If it's the point where the flexi hose meets the wall fitting, you might just require a replacement washer to seal the leak. I'd suggest unscrewing the flex hose via the ribbed fitting and seeing if the seal has perished.
If you can purchase a suitable hand-held shower, then typically, they'd only require thread tape to seal it.
Hi Mitchell,
It looks like it's leaking from some point in the flexi hose. Where the hose meets the wall fitting, it's completely dry.
Looks like I'll need to get a hand-held shower and thread tape then to fix it.
Is it as simple as wrapping the tape around the wall fitting a few times before screwing on the new fitting?
Hello @yohfdo
Yes, it is that simple, please make sure to do a minimum of four rounds around the threaded exit. If the washer in the hose is gone or broken, I suggest replacing them with Kinetic Handshower Washers. But if the hose itself is damaged, I recommend the Kinetic 2m Stainless Steel Shower Hose.
