Hi everyone,
Ceiling exhaust fan grille broke but can't find anywhere the same model. Anyone knows where I can get this?
Otherwise, I've see this option at Bunnings:https://www.bunnings.com.au/blauberg-125mm-white-round-ceiling-grille_p4420518
Anyone knows if it works as a replacement? I couldn't find information whether it's a "clip-on" like my previous one.
Hello @qpeak
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about replacing your bathroom exhaust grill.
Replacing a broken bathroom exhaust fan grille can be straightforward if you find a compatible model. If your current grille has a "clip-on" feature, it's crucial to check that the replacement is also clip-on, as models vary in attachment methods. The Blauberg 125mm White Round Ceiling Grille that you mentioned may work, but ensure it fits your fan's dimensions and attachment style. If you're uncertain about compatibility, make sure to take measurements or consult with a team member at the store.
However, should you consider replacing your bathroom exhaust fan, the store has several options. Wall or ceiling-mounted fans, such as those from HPM or Ventair, are straightforward replacements. For enhanced ventilation, ducted fans vent air directly outside, ideal for windowless bathrooms. Inline fans, installed in the roof cavity, operate more quietly, with brands like Blauberg offering models for larger spaces or multiple rooms.
For added warmth, consider a heat and fan combo unit, which combines an exhaust fan with heating lamps, perfect for cooler months. Just ensure the fan’s size matches your ceiling cutout and that it provides enough airflow for your bathroom size.
Hi @EricL , thanks so much for the reply!
Just wanted to confirm - you mentioned that the Blauberg 125mm White Round Ceiling Grille may work. Would you be able to confirm if this model is like a "clip-on". It's hard to tell from the picture on the website. Dimensions available looks like it will be a fit!
Sharing here a closer snapshot of the "clip-on" of my current grille.
Thanks also for the idea about replacing the exhaust fan - had no idea there was a heat and fan combo! We're not looking to invest in something like this at this moment but really great to know about it.
Hi @qpeak,
The Blauberg 125mm White Round Ceiling Grille does not have the same clip-on system as what you've depicted in your image, and it would be quite unlikely that a cover for a different light fits on your model. The only way to tell would be to purchase one and try it. You can always return it if it doesn't fit.
In all likelihood, you'll need to have an electrician replace the entire exhaust fan. Alternatively, if you can figure out the brand of your unit and model number (potentially written on a label on the back of the fan motor), you could contact the company to see if they still make a replacement cover.
Hi qpeak, wondering what you did/if you found a solution? I have what looks like the exact same model and problem 😅
Welcome to the Bunnings Workshop community @Zylo. It's wonderful to have you join us, and many thanks for your question on exhaust grills.
Let me mention @qpeak so they are alerted to your question.
As these are proprietary fittings to that manufacturer, the best place to start would be with the manufacturer of that exhaust fan. You might find details on the motor housing on the back of the unit. Failing them to supply a replacement, you might consider replacing the exhaust fan, and we have several with the fan/light combo.
