I’m having difficulty installing a new toilet roll holder on our spare toilet in the laundry.
The old toilet roll holder was installed using a gravity toggle, vertically.
Unfortunately the plate to install the new toilet roll holder can only be installed horizontally.
I drilled holes and clearly hit a stud. I used the stud finder and it keeps indicating either electrical wiring or studs.
I then tried two versions of liquid nails but neither held it securely once I attached the entire holder.
I would appreciate any advice as to how I can solve my problem.
Oh dear, I am sorry I thought I could help but I don’t think so. I removed my old toilet holder because it was ugly and bought a suction holder from Bunnings. It fell off a few times until I read the instructions but it hasn’t fell off for a year. I better leave this to the experts.
Thank you anyway!
Let me tag our resident Bunnings D.I.Y. expert in @EricL to assist you this afternoon @Missskybird.
Thanks for your patience,
Hello @Missskybird,
Many thanks for sharing your question about how to replace a toilet roll holder. I'm sure our resident D.I.Y. expert @EricL would be happy to assist you once he's online later on in the day.
In the meantime, sharing a couple of related resources below that you may find useful:
Akanksha
Hello @Missskybird
I suggest moving the location of the toilet roll holder just a few centimetres away from the plumbing or electrical services indicated by your stud finder. Looking at the installation manual the mounting plate has two holes for two screws to go into. I recommend using Ramset 6 x 38mm Universal Anchor. This will allow you to install two anchors in the wall side by side. My number one tip is to drill pilot holes for the plugs so that you can install them side by side.
Hi Eric
i have tried that several times hence why I resorted to Liquid nails.
It seems like there is quite a lot of timber and wiring in the walls. The house is over sixty years old so nothing would surprise me.
The metal plate you screw onto the wall will hold the plate but once I try to attach the holder it falls off the wall.
Any other suggestions? It is so frustrating 🤦♀️
Hi @Missskybird, that's an interesting description, but I am having trouble picturing what's happening for you.
If you have found a wooden stud then you should be able to screw the backing plate securely to the wall at that point using timber screws. The roll holder should then attach to it either by a small screw, usually located out of sight on the lower edge, or else it will be rotated to lock it onto the plate (depends on the brand/model). I guess you'll know which method.
When you say it falls off the wall when you attach the holder do you mean the backing plate and all falls off, or just the roll holder section ?
If it all falls off then the plugs that you are using to hold the backing plate have not spread out and gripped the back of the wall as they should. This could happen if you drill the holes too big. The plugs need to be pushed firmly in and grip the side of the plaster as they go. If you screw directly into the timber stud instead then you won't have that problem.
The whole lot falls off.
I was attempting to attach the backing plate to the wall with liquid nails as I had been drilling into the wall so that I could you the plugs and screws supplied unsuccessfully.
Thank you I will just give wood screws a try.
Also could you let me in on the secret way to screw that tiny little screw into the bottom of the holder? It’s impossible 🤦♀️
Hello @Missskybird
I'll be passing by one of the stores tomorrow, let me double-check the mounting instructions for you. The only other possibility that comes to mind is that your wall might be a brick wall that's been covered over with Gyprock. This means that you'll need to use a masonry drill bit to drill into your wall so that you can mount your toilet roll holder.
