How to replace Caroma old Fowler (square) flush outlet valve?
Kintiq
I have successfully replace with  aroma Quiet Flow 2 outlet valve but it is no longer available , it seems Gibret Flush out let valve is similar to Quiet Flow 2 . Any help with dimensions of Gibret will be appreciable
Re: How to replace Caroma old Fowler (square) flush outlet valve?
Hello @Kintiq
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your cistern's outlet valve.
The Caroma flushing valve also known as the QuietFlow M5 Outlet valve 750085 is still available but will need to be specially ordered at the special orders desk. It has all the parts necessary for it to work inside your Fowler cistern. In regards to the inlet valve, it can be replaced with a standard Fluidmaster Bottom Entry Toilet Inlet Valve. It is totally adjustable both the float and post height can be changed.
Thanks EricL
I wonder why can't we see the price of products to be ordered through special order?
Could you please also advise how to remove the flush bottom pipe to insert new washer under  cistern's  Flush outlet ; I tried to push it down but found difficult and was afraid not to break anything, your expert advise would be most welcome. Thanks
Flush Pipe - How to remove the marked end to insert a washerFlush Pipe - How to remove the marked end to insert a washer
Hi @Kintiq
I suggest speaking to the special orders team at your local store and asking them for a quote on the spare part you need for your toilet. The reason you can't see the price for the part is because it is not a regularly stocked item. To remove the flush pipe under your cistern the big white locking ring must be turned anti clockwise first to loosen it up. Once the locking ring is loosened up, you'll be able to slide the flush pipe out.
Thanks Eric
Perhaps I should get an extended wrench - That may be required to loosen up the nut above, but I could not find those  wrenches in Bunnings
Hello @Kintiq
You can either use the Haron 160mm Strap Wrench or the Haron 10" Slip Joint Pliers.
Thanks Eric
I was not aware of the name Slip Joint Pliers - I will get that , I am not very confident with Strap wrench although saw them used for Engine Filters - removals .
Hi Eric
Thanks , I went to Bunnings to buy that Haron 10" Slip Joint Pliers but found it could only open up to 45mm dia, as the pipe is 50mm hence the Hexagonal nut perhaps should be more than 45mm, hence brought a Trojan one seems a bit bigger will try.
Hi @Kintiq
Please keep us updated with your progress, we look forward to seeing your toilet cistern repaired.
Hi All
I did it today using the new Slip Joint (SJ)
Pliers, however found the Nut is not a hexagonal see photos but round with gripping ridges.
The main problem I faced during tightening the nut , the thickness was not enough to have a full grip with the SJ Pliers, I had to struggle finally I tightened it to NO LICK position.
After all that I realised I am n o longer young with bad back, I will get a Plumber to help me next time.
