I've discovered a hairline crack in one of the tiles in my shower, and I'm concerned that replacing it might compromise the waterproofing. Since I live in an apartment, damaging the waterproofing during tile replacement would be a major issue. Could you please advise on how to fix this without risking damage to the waterproofing?
Hello @saroj9
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your tiled floor.
In this particular situation, I can only suggest putting Selleys 300g Wet Area Waterproof Silicone Sealant - Dark Grey and spreading it with Pro Renovator 38mm Plastic Scraper - 38mm. Your goal is to push the silicone into the crack as much as possible and leave a miniscule amount on the surface covering the crack.
Please note that this is a temporary repair and at some point, the tile will need to be properly replaced. I'm sorry, but I'm currently unaware of a long-term repair method for damaged tiles. I also recommend getting some quotes from tilers who are familiar with tile bathroom repairs. This will give you the opportunity to prepare for the cost of the repair.
