Hello.
We are wanting to DIY this laundry and have a Kaboodle Laundry all planned out. However we have some questions on timing and how to get started if you can please help (existing laundry and plans below):
Hello @Starboard
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your laundry renovation.
I suggest having a quick look at this guide - How to plan a laundry renovation by @Adam_W. In regards to your renovations steps, it looks perfectly fine. To save yourselves a bit of tiling it is not necessary to remove all of the tiles only what needs to be removed due to plumbing. I'm not too sure about the vinyl tiles as some of tiles will need to removed due to the relocation of plumbing.
As to the waterproofing, I suggest double checking the rules and regulations in your area so that you know how much water proofing is needed. If 150mm is all that's needed, then you can stop at that point and not damage the wall further.
That's great. Thanks very much for your help, Eric. Would you know if there is a guide to how to install the cabinetry to the wall, or does that come when it's purchased?
Hello @Starboard
Installing your wall cabinets is pretty much like installing your base cabinets. You just need to make sure that there are studs behind them and that each cabinet must be securely screwed to each other to provide horizontal support. I suggest using Tradesman Stan the Stand Cabinet Levelling System or similar to support the wall cabinets while you are screwing them in.
I suggest getting a second pair of hands when installing your wall cabinets for safety.
Hi @Starboard,
Just thought I'd add that you might find the guide How to assemble and install laundry cabinets by experienced member @Adam_W very useful.
