SuseMck
Cultivating a Following
How to install floor trim?
Can anyone tell me how to fix these two trims in place?
1. T strip - doesn't come with channel to clip into, will be between tile and laminate flooring, I have only seen liquid nails as an option.
2. Cove trim - installed after tiling, adhesive??
Thanks heaps
Re: How to install floor trim?
Hi @SuseMck,
Many thanks for your question. Would you also be able to share a photo of where you are installing the trim so members can see what you are working with?
Thanks,
SuseMck
 T strip for doorway (can't use anything that screws down as this is too close to a join in the subfloor). Also to fix below.
 Cove trim to possibly cover the silicone job along acrylic panels.
"Just because you're qualified to do something, doesn't mean you're good at it."  My mum.
I'm making my way through tradie substandard work.
Hi @SuseMck,
Liquid Nails would be the general go to in such a situation for the T-strip. Any reason why you wouldn't use it, or have you had issues with it failing in the past? You'd use a wet area silicone for the cove trim to adhere it to the tiles and acrylic panel.
SuseMck
Thanks @MitchellMc . All of the trim that had been glued down has lifted (but it wasn't the correct fixing for the trim profile). I just wanted to double check before I fix them all. Cheers 😄
