How to install bathroom tap?
PatDIY_Dad
Having an Impact
We bought a new swivel bath tap so it's safer for the kids
The original tap had an adapter that screwed into the threaded pipe on the wall (picture above) and it had a spigot that goes into the tap
This new one just has the female thread but the pipe in the wall only sticks out a few mm
Can I get an adapter to lengthen the pipe.so.i can screw in the new tap flush to the wall
I tried it without any adapter but it only allows 1 full turn before the tap gets too tight against the tiles and it just leaks when the water goes on
Re: How to install bathroom tap?
Hi @PatDIY_Dad,
Unfortunately, it sounds like you're going to have to cut the supply pipe back by 5mm which is not something I can recommend as a D.I.Y. job.
You might need to contact a plumber for assistance on this one.
Hey I feel dumb but resolved it
I just put alot more Teflon tape and it stopped leaking
It still isn't on that much thread but I'll keep an eye on it
I didn't use the adapter in the end
Hi @PatDIY_Dad,
Trial and error don't make you dumb; I find it one of the best ways to learn.
Glad to hear you found a solution but keep an eye on it as you wouldn't want it to burst.
