How to install Ramset M4 x 8mm Hollow Wall Anchor?
zillah
Building a Reputation
Dear Expert
I uses Ramset M4 x 8mm Hollow Wall Anchor
https://www.bunnings.com.au/ramset-m4-x-8mm-hollow-wall-anchor-10-pack_p2260115?store=7379&gad_sourc...
At a bathroom to install new a toilet roll holder,,,,,I bought the one in the link above assuming the thickness of plasterboard is 13mm
I followed the installation instruction on the box (attached) it says :
1- Drill an 8mm diameter hole into the substrate
2-Tap the anchor into the hole until it is flush with the surface of the substrate
3-,,,,,,etc
I tried to use two wall anchors both of them their legs not expand like the fifth attached photos (from Bunnings website) and hence
the anchors were spinning inside the hole
IMG_5021.jpg IMG_5022.jpg IMG_5023.jpg IMG_5019.jpg Hollow Wall Anchor.png Installtion Instruction.jpg
Thx
Re: Ramset M4 x 8mm Hollow Wall Anchor failed to get it installed
Hi @zillah,
It's great to hear you've had some success with @Jewelleryrescue's method.
The anchor setting tool would definitely be handy if you plan to use these anchors more in the future.
Thank you for the update.
zillah
@JacobZ
Do you think Ramset anchor setting tool  would work with Macsim Hollow Wall Anchor as well ?
https://www.bunnings.com.au/macsim-8mm-yellow-zinc-hollow-wall-anchor-80-pack_p0057439?srsltid=AfmBO...
Thx
Hi @zillah,
I can't say I'm sure, but considering how similar their designs are, I'd say it's likely that it would work.
zillah
Noted and Thx Jacob
