How to install Estilo shower base and screen?
Pete50
Hello ,
Im assuming the Estilo 900mm x 900mm 4 Lip Centre Rear Outlet Shower Base will fit with the Estilo 900 x 1830mm White Semi Frameless Shower Screen. Or, do I need the 3 lip model ?
For fitting of screen does it depend on how far into wall base is fitted ? ( checked into wall framework to allow finished tile to sit over the lip.?} .
ie. Do the 2 walls of shower screen have lateral adjustment ?
Thank You
Re: Estilo Rear Outlet Shower Base , Estilo 900 x 1830mm White Semi Frameless Shower Screen
Welcome to the Bunnings Workshop community @Pete50. It's great to have you join us, and many thanks for your question about shower screens.
You're correct that those products are compatible with each other.
You'll notice that the base has a raised section on it. The screen can be placed anywhere between the two arrows and moved around to suit how far the base is rebated into the wall. The raised section is quite wide, so you have plenty of available movement.
