Help our cleaners used a steel wool scrubber in the toilet bowl & have scratched the bowl. Any advice please on how to fix or should I tell them they will be replacing it?
Hello @aloughnan5
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about fixing your scratched toilet bowl.
I propose using Bar Keepers Friend 737ml Liquid Soft Cleanser. It is effective at removing rust stains, metal tarnish, mineral deposits, soap scum, and everyday grime.
The toilet water in the pan must first be removed, this can be achieved by using a small hand pail and scooping the water out or using large rags to soak the water out. The area to be treated must be dry otherwise the cleanser will dissipate and not be totally effective.
Once you have all the water out and the pan is dry, grab a dry clean rag and place some cleanser on the affected area. Allow the cleanser to soak for a minute before you start wiping it clean. Vigorously rub the metal scratches until they totally disappear.
If the damage is too deep, I'm afraid it can't be patched or repaired, and the pan will need to be replaced. Please note that you must refill the toilet pan with water after your attempt, this is to prevent sewer gasses from entering your home.
Please remember to wear personal protection such as disposable gloves and goggles when working on your repairs.
I use pumice. You should be able to sand scratches out with pumice.
Also the easiest way to remove water is to take a small bucket and pour half a bucket full of water into toilet and it will flush with the water level staying low. It's amazing but it works every time!
Welcome to the Bunnings Workshop community @GotoHell. It's great to have you join us and thanks for jumping into the conversation.
Thanks for the suggestion, I'm sure our members will appreciate it. A word of warning, though, that pumice in itself is an abrasive. You need to use caution and to go too heavily on the glazed ceramic bowl, as once that glaze is removed through an abrasive cleaning product or action, it opens up the porcelain beneath, and stains won't come out of that as it is porous.
Looking forward to hearing all about your projects around the house and garden. Feel free to reach out anytime you need assistance of have something to share with the community.
