Hi everyone! I’ve always had top loaders but I had to move house (rental being sold) and this laundry in this new place could only accommodate a front loader. Bought one yesterday and upon using it, it is leaking from the nipple connection. I can’t see any other way to connect this hose. Should I just tape it or get a longer hose as it’s pulling a bit. I can’t modify it as it’s a rental, it just doesn’t seem like the right connection. Thankyou!
Welcome to the Bunnings Workshop community @sarahlo. It's great to have you join us, and many thanks for your question about connecting a washing machine waste.
You need a clamp on that hose to prevent leaking, and this Prime 22-38mm Solid Butterfly Screw Band Hose Clamp should be just about right. Just slip the clamp over your hose, push the hose back onto the barb, and position the clamp so it is over both the hose and the barb. Once you've tightened the clamp, it should stop the leak and prevent the hose from blowing off completely.
Thankyou so much I’ll go get one today
This has worked so far no leak thanks so much!
That's great to hear, @sarahlo! Thanks so much for coming back and letting us know that the solution worked for you.
Please remember that we are always here to assist with any projects you have going on around the home. Give us a shout any time you need help or have something to share.
