Hi all,
I am was thinking to cover these tiles with Renovation Range Tiles & Benchtops Satin.
I also want to smooth them like this video but I have NO IDEA what to buy to serve the purpose well.
Here is the video : https://www.youtube.com/watch?v=9xm9KTv0ziU
I will appreciate your help.
Hi @ddel,
To clarify, you'd need to use the Dulux Renovation Range Floors. The Tile And Benchtops Satin is for wall tiles, not floor tiles. I just didn't want you to go with the wrong product.
Ardex Feather Finish is typically used to smooth over grout lines before laying flooring over the top that needs a smooth substrate. What was your end goal? Did you want a perfectly smooth floor surface in your bathroom that doesn't look like it's tiled?
Note that the Dulux Renovation range is designed for tiles not to coat a cement surface, such as the Ardex Feather Finish.
"Did you want a perfectly smooth floor surface in your bathroom that doesn't look like it's tiled?"
YES, this exactly!
Epoxy is not really what I want...Microcement is the ideal choice but it is apparently unavailable in Australia for whatever reason and it is not a DIY thing.
Hi @ddel
Have you considered using Smart Home Products 2.22m² Havana Waterproof Aquaguard Hybrid Wide Planks on top of your tiles? It's a great way to upgrade your flooring without having to remove the tiles in your bathroom.
Here are some great examples of hybrid flooring:
