Can anyone advise me on a starting point for getting a second bathroom/toilet (ensuite) for my home?
Hi @CapeHoney,
Thank you for your question about adding a second bathroom to your home.
Was the plan to add an extension to the home? Or to simply renovate the existing space to add a bathroom or ensuite?
The likely place to start is with your local council to find out your requirements in terms of building approval. The next step after contacting your council is to get in touch with a draftsman and a builder. They will be able to assist with the design and construction of the bathroom to ensure you are in line with the relevant legislation and building codes.
If you are looking for a place to start in terms of designing a new bathroom, uploading some images of the proposed space would help our members offer their advice based on the specifics of your situation. You can also check out How to plan a bathroom renovation for some guidance on designing a new bathroom and our Top 10 most popular bathroom projects for some inspiration.
Also, allow me to tag some of our helpful members to see if they have any advice or inspiration they can offer, @ProjectPete, @Nailbag, @Dave-1.
Good Evening @CapeHoney
Only a few things I can add to @JacobZ's suggestions
If you know where your sewage and water services are and have acces sto underneath your house then you can start formning ideas. Then contact a builder with them and see what is feasable. If you dont have access to where they are under the house then I would be thinking of having the new bathroom backing onto the older one tho this may entail expensive concrete cutting. A builder to be contacted again with your ideas on this one.
Getting an idea where your services are and working with them may save you money when building a new room.
A sketch of your house plan with existing services marked would be a good place to start and would help our suggestions
Hi @CapeHoney
I would look at getting the advice from a local draftsperson. They have the qualifications and experience to know what's possible both from a structural perspective and design. They will also be the person to put the plans together for quotations and submission to council for the building permit when your ready to go ahead.
Nailbag
