Does shower niche need to be fixed to the studs?
charlie01
I was watching video "How to build a wall niche" and noticed the niche in the video is secured to the plasterboard instead of studs and noggins.https://www.bunnings.com.au/diy-advice/home-improvement/shelving-and-storage/how-to-build-a-wall-nic...
If I install a Mondella shower niche (https://www.bunnings.com.au/mondella-365-x-320-x-90mm-shower-niche_p0332308), can I use the same method? But manufacturer's instruction says the niche should be secured to studs and noggins (https://media.bunnings.com.au/api/public/content/0bec097b427848cebf0614a9993facdf?v=aeeac488).
Re: Does shower niche need to be fixed to the studs?
Hi @charlie01,
Thank you for your question about installing a shower niche.
The niche used in the video How To Build a Wall Niche is a plaster niche, which is slightly different from the Mondella 365 x 320 x 90mm Shower Niche.
Unfortunately, the only appropriate method of installation for the Mondella shower niche is to screw it to studs and noggins as shown in the Installation Instructions.
