Hi All,
Need some advice. I struggle to keep my basin clean and I accidentally used a metal scrub and scratches the basin very badly. I since try using all sort of cleaner to clean but not able to clean and it just get worst. I thought of changing it to a better basin and start maintaining it from there. I checked the measurement around 55cm length and 39cm wide. And it is oval shape. How do I find a one that really fit myv basin table top without recutting to fit new basin? Did it need to be exact size? I tried finding and hardly can find any similar sizes ( which I thought usually be the standard size). The only one I found closest to my size measurement is 565mmx395mm white Centro vanity with 3 tap holes (below the link). Wonder if it able to fit exactly? And if anything I need to consider?
https://www.bunnings.com.au/caroma-565-x-395mm-white-centro-vanity-basin-with-3-tap-holes_p5120022
what manufacturer tap/cistern tap are those. ? looks good quality.!
Welcome to the Bunnings Workshop community @thilaksr.
Let me tag @calccom21 so they are alerted to your question. I suspect they either used the Kinetic 15mm Chrome Mini Cistern Cock or Syneco 1/2" Chrome Mini Cistern Cock, as they both look very similar.
Shout out if you need any assistance with your project.
Hi - not sure what quality - definitely not those premium ones... i think it costs few bucks if i recall
