Can you use the Estilo duckboard in the shower?
Cranswick
Cultivating a Following
Hello Regarding your Estilo timber bath/ shower mat ( See photo below )  is it desgined to go inside the shower to stand on while you are having a shower and can get wet? or is it designed just for the bathroom floor outside the shower ?
Re: SHower bath duckboard
Hello @Cranswick
The Estilo Duck board is not made for constant immersion inside showers or baths. They are only designed to be stepped on once you are out of the shower or bath. The purpose of the duckboard is to prevent you from stepping on to wet, soggy floor towels.
Cranswick
thanks are there similar duckboards anywhere l can buy that are designed to go inside the shower and get wet, such as teak wood or are are all wood duckboard mats designed only for outside the shower? . On the internet l saw some photos of people who had wooden duckboards inside their shower to stand on, is that a good idea if you want something inside the shower thats comfortable and non- slip ( See Photo below)
Hi @Cranswick,
I am not aware of any timber duckboards designed to go within the shower recess. Timber won't last long in the shower cubicle getting wet on a regular basis. These duckboards have a limited lifespan even when used outside the shower. I would suggest you look towards products such as the Barelli Non-Slip White Rubber Bath Mat - 53x53cm. That should provide more comfort and a non-slip surface.
