How to remove waterproofing tin lids?
haveago
waterproofing tins with a hook lock on them, trick to remove lid once that hoop is off them
Re: waterproofing tins with a hook lock on them, trick to remove lid once that hoop is off them
Hi @haveago,
Could you provide a bit more information and maybe some pictures of the container you're referring to? That would help our members understand the type of lid and locking mechanism you're dealing with and offer the best suggestions.
If you are referring to one of the locking jars I've pictured below, sometimes the gasket can hold the lid shut. Once you've released the clip, submerge the jar in the sink in some warm soapy water and let it soak for ten minutes. This might soften and loosen the gasket, allowing you to gently pry the lid open.
Many thanks.
Noyade
"hoop"
This maybe?
If it's the locking mechanism @Noyade has shown, I typically place a flat-head screwdriver blade on the container rim just under the lid edge. I then lower the screwdriver handle below the level of the lid and give the handle some tappity tap taps with a hammer in an upward direction. You might need to do this around the lid, but that's normally enough to dislodge it.
