Id like to update my staircase to be a bit less 2000s. How would I go about replacing stair spindles and where can I buy new ones from?
Hi @Jersey1975,
What type of spindles are you considering for your staircase update? It's unlikely you'll find spindles that can simply be swapped out for the existing ones, as different designs often require adjustments to fit properly.
If you're open to an alternative, painting your current spindles black could significantly refresh their appearance without the need for replacement.
It might be best to consult with a professional carpenter or staircase specialist to assess your options. They can guide you on what replacements are feasible and whether your staircase structure supports the changes you're envisioning.
