Is it necessary to oil hybrid or even possible to oil hybrid floor boards
Welcome to the Bunnings Workshop community @Artiej24. It's sensational to have you join us, and many thanks for your question about hybrid vinyl flooring.
It’s not typically necessary to oil hybrid vinyl flooring, as these floors are designed to be low-maintenance and durable. However, if you notice that the surface has dulled, especially in high-traffic areas, it could be due to wear and tear rather than a need for oiling. If that’s the case, I recommend contacting the manufacturer of your flooring to inquire about any rejuvenation options they may offer. Depending on the brand and type, some hybrid floors can be restored with specific treatments.
In the meantime, you might want to try using a product like Long Life 1L Self Shining Floor Polish, which is suitable for vinyl floors. Over time, this can help revitalise a dull or worn surface by adding a protective layer and restoring its shine. I'd suggest trying it in an inconspicuous location first to ensure it doesn't discolour your flooring, especially if the top coating has been worn down.
