I tried hanging this, but the hinge clips can’t reach the nail because they’re attached to the backboard rather than the frame. Does anyone have any suggestions?
Hello @humbleguy
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about hanging your picture frame.
I suggest using Ramset 6 x 38mm Universal Anchor, but instead of using the screws provided I recommend using the Zenith 8G x 75mm Countersunk Rib Head Chipboard Screws. They are bit longer and will stick out of the wall a bit which should be perfect as it will catch onto the hooks of your picture frame. If you are going into brick, masonry or plasterboard the Ramset Universal Anchor can be used. But if you are going through timber the chipboard screws can be used by themselves.
Here is a handy step-by-step guide: How to hang just about anything by @Adam_W
