how to install a Goliath cover stay steel hinge with swivel feet?
Welcome to the Bunnings Workshop community @briannaridge. It's sensational to have you join us, and many thanks for your question about Goliath cover stays.
Was it the Goliath Silver Metal Cover Stay that you are enquiring about? Was there any particular question you had or parts of the installation you were finding difficult?
Start by preparing the door and frame to ensure they are clean and free of debris. Hold the stay in place on the door, aligning it so that it can hold the door at the desired open angle. Mark the positions for the cover stay on both the door and the frame.
Attach the stay to the door using the screws provided, but don’t fully tighten them yet. Next, move the door to the desired open position and secure the other end of the cover stay to the frame with the screws provided. Again, avoid fully tightening the screws until you’ve checked the door’s movement.
Adjust the stay if necessary to ensure smooth operation. Once everything is aligned and functioning correctly, fully tighten all screws. Finally, open and close the door several times to make sure the stay holds the door in place as intended.
