bitumen waterproofing
capelli
Community Newcomer
We have used the bitumen waterproofing on the front side of the downstairs area of the now enclosed studio area to stop water seeping in one area.
should we go all the way around the downstairs exterior even though there are no other areas where water is getting in?
Re: bitumen waterproofing
Hi @capelli,
It is difficult to say without seeing the area that you are referring to. If you can upload some images, then I'd be able to make a much more educated determination. Let me know if you need a hand uploading images, I'm happy to help if required.
I imagine painting the rest of the area with bitumen membrane won't have a negative impact and will add an additional layer of protection. If it does not detract from the aesthetics of the area and you have additional bitumen membrane, it might be worthwhile to widen the area that you have waterproofed, but without seeing it, it's impossible to say whether you need to or not.
Once you've uploaded some images, I'd be happy to advise further.
