Hi, I'm needing (well probably more wanting) to purchase a new wet and dry workshop vac. I've currently got a Ryobi which I must say, has been treated dreadfully & the accessories have disappeared so will now be relegated to mostly outdoor jobs.
I've been looking at a Milwalkee M18, although I don't love battery reliant, the Karcher WD6 or getting another Ryobi, all of which will have far kinder working conditions.🤣
Notes on my projects:-
Sorry, this has been so long, but I would love to know what everyone thinks about something that vacs, drinks, blows, has a decent range of accessories (& can add aftermarket), plug for sander etc, filters that won't require me to remortgage my house.
Current salvage yard / deck workshop projects
Daybed needs reinforcement, paint etc
Big Mumma Tool Shed Wardrobe
OG Daybed
Fireplace surround struggling to live
Spray Room Wardrobe Pre Shelve / Drawer conversion
Hairy and bossy Migaloo
Most controversial wardrobe ever
Morning @victoriacalhoun
Now that is an impressive list! I wouldnt know where to start lol, but so much fuin to be had!
As to the question about a wet and dry vac. I have only used wet and dry vacs to suck up water at work when I have had 3cm worth across the floor. In your post you dont mention any liquid so I am wondering if you just need a vacuum instead? I have had a vacuum die because of plaster dust that was sucked up 😕 So maybe a wet and dry has a better fine filtration?
I am old school and much more prefer brooms and hand brushes to clean an area before the final vacumn (less chance of re-killing that plaster vacumn again)
As to brands to use, I strongly support Ozito (for battery powered tools) and Makita They both just keep on going. The ozito product range will be using the same model batteries for the next several years so I dont need to worry about the skins and they come with a warranty so if they break in the first year or 3? (not sure anymore) then they will be replaced. It depends on how oftern they are used and how they are looked after. If you use a tool once a year for a little and then it sits there doing nothing for a chunk of time. It wont handle it too well.
Maybe wander through the aisles and see what types of equipment each brand has, I know both ozito and ryobi have "bits" that I look at and think "really"? As in they are surplus to need...
Ratio of $$$ + amount of use + type of use +ease of use + warranty = product line
Hi @victoriacalhoun,
As @Dave-1 has said, that is quite a list of projects. I'm excited to see and possibly help them come to life.
There is a vacuum for everything and finding the right mix between price, performance and compatibility is not exactly easy. I'll try to offer some personal insights as well as some examples of what is out there to help guide your thoughts.
I can't speak to the quality of the Karcher Wet and Dry Vacuum WD 6 Premium as I haven't used it, but Karcher is a fantastic brand for wet and dry vacs. I have however used this Karcher 1380W 30L M Class Wet / Dry Vacuum which performs fantastically and I can't fault it in any way.
I own a Ryobi 20L Stainless Steel Wet Dry Workshop Vacuum RVC-1220I-G which I am also not very kind to. For what I put it through, it has held up extremely well and for the price I paid, I am extremely happy with its performance.
I also own a Makita 18V Brushless Wet/Dry Dust Extractor DVC750LZX1 and a Makita 42L Wet/Dry Dust Extraction Vacuum from when I worked on commercial construction sites that required dust extraction to be used with power tools. Being Makita products, they are very good for use with Makita tools and have some amount of cross-compatibility with other tools.
The majority of power tool brands have their own vacuums that are designed to be compatible with their tools. They often refer to them as "dust extractors" as opposed to vacuums as they are intended to be attached to tools to prevent airborne silica dust and other hazardous materials.
Some examples include:
Another thing to consider is the hazard class of the vacuum. Higher-end vacuums come with HEPA filters that are classed as L, M or H. Once a HEPA filter comes into play, the price tends to jump considerably.
You might like to have a look at Selecting the right portable extractor or industrial vacuum cleaner for hazardous dusts for some info on what these hazard classes mean.
I hope this has helped to clarify a little what is out there.
Please don't hesitate to ask for clarification, I understand that there's a lot to take in.
Thanks @dave-1 & @JacobZ
Jacob, I am too scared to re-read your message as I literally wanted every one of your product suggestions!
Dave, I am a bit like you in that I do actually like a broom and hand brush (should probably not make that common knowledge if you saw the leaves in the driveway atm...). I actually have a couple of Ozito corded tools that have been great, but I will confess, that I don't award them the same love I have for some of my other corded or petrol tools that are well known brands. I actually used an Ozito jigsaw, completely off label use yesterday morning as I had to frantically cut up a frozen marrow bone for my hound as penance / bribery for having a JOB!!!
So thanks for the recommendation. You subsequently sent me on an online Bunnings bonanza of Ozito PXC products and batteries. So we shall see. & even though I didn't say much about needing the wet function of a workshop vac, I do spray out my tanning booth, the walls and polished concrete floors of the spray tan room regularly and that needs drinking up (not like a tsunami) as opposed to the front deck which I can high pressure hose and sweep.
Let my 5,000 projects begin. Thank you again Dave and Jacob.
