Screws!
prvz27
Building a Reputation
Screws!
Hi everyone,
One thing that overwhelms me as a beginner, are screws and bolts. I don't quite understand the numbers on them, the gauge and which gauge to use in which situation, as well as bolts, I don't understand why bolts should be used as I have seen people using them in woodworking projects.
Does anyone have a resource that I could check out which goes over these points?
Thanks!
Re: Screws!
Hi @prvz27,
The gauge of a screw is the thickness of the shank. The shank is the un-threaded section of the screw. The higher the gauge the thicker the screw. A thicker gauge indicates better shearing resistance capabilities in a high torque situation. Commonly, in terms of number, the gauge will come first then the length of the screw will follow.
Let's take a look at Buildex 8-10 x 40mm Climacoat Countersunk Ribbed Head Treated Pine Screws. The numbers are 8-10 x 40mm, so obviously the 40mm is the length. 8 is the gauge (thickness), and 10 indicates how many threads per inch. The more TPI the finer the thread.
Bolts work a bit differently and generally have their thickness followed by their length. You'll notice both metric (millimetre) and imperial (inch) versions available. Whether you use a metric or imperial bolt will likely only be relevant if you are tightening them into pre-existing hardware or matching them to others. It is irrelevant if you are just bolting two pieces of timber together. If you ever run into a bolt description similar to M3 x 1.25 x 30, they are indicating it is a Metric 3mm shank x 1.25mm between threads x 30mm long.
Finally, there are different thread pitches (the angle of the thread). You might have run into this issue when you have a nut and bolt that look the same sizes but then cross-thread when you go to tighten them up. Those thread types are the inch-based Unified coarse/fine (UNC/UNF) and metric coarse/fine.
In regards to what gauge and thickness to use in which situation, think of it as the more force on the joint that the screw is holding the larger length/gauge you should use. Obviously, this has exceptions and at times two smaller screws are better than one longer screw. Bolts can be used over screws when there is not great joint strength and you wish to clamp it together. A bolt squeezes two structures together and provides superior holding strength over screws.
I hope this helps and hasn't confused you even more.
Please feel free to let me know if you need further information or had questions.
prvz27
Re: Screws!
That was super helpful @MitchellMc , Wasn't confusing at all!
Re: Screws!
Hi Mitchell, here’s what I found on the Allfasteners website…
The description of the size of screws is commonly listed as three figures – firstly the gauge, second the threads per inch (TPI) and the third figure is the length either by inches or millimeters (mm).
For example:
  • 14-10 x 25mm indicates a 14 gauge screw with 10 TPI and 25mm in length
cheers, Volvoide :smile:
Re: Screws!
Welcome to the Bunnings Workshop community @Volvoide. It's marvelous to have you join us, and many thanks for jumping into the discussion.
What I posted is an overly complicated explanation, and on second thought, it's not entirely correct. Your wording conveys the meaning in a much simpler manner, so I've changed my previous post to reflect that.
Nice pickup.
