Need replacement screw for LG Stick Vacuum Cleaner
NumeroUno
Cultivating a Following
Hi
Does bunnings sell this specific screw at the Balcatta store in Perth? It's for a vacuum cleaner.
Re: Replacement screw for LG Stick Vacuum Cleaner
Hi @NumeroUno,
Thank you for your question.
Unfortunately, it would be nearly impossible for me to give you a yes or no answer to this question from photos alone.
The best thing you can do is take the screw and possibly even the vacuum in store with you and head to the screw aisle. In this aisle, you will find a thread tester that you can use to determine the gauge (diameter) of the thread.
Once you know the gauge of the screw, you can look through the available options and compare your screw with them or test if they fit in the vacuum.
I'm sure the helpful Builder's Hardware team will be happy to assist.
